Can someone verify my screen is the same size as normal? My body guy suggested mine is ‘smaller’ than normal
First, is the body guy used to seeing OTS windscreens? FHC is certainly smaller than OTS.
Second, there are two different screens for FHC, although as I recall you are in England so probably have a RHD, and there were only two RHD cars with the early screen so you probably have the later screen.
I have 679187 which has the early screens. Here are some pix of mine.
Sorry I don’t have a metric tape.
thank goodness!s English car imperial tape measure the way it should be
Great info thank you. My car is in fact an LHD which I am converting to RHD. Apparently the earlier cars with the central windscreen bar use these smaller screens with the associated chrome trims, which are unobtainium. After cars used bigger screens and no central bar.
