123 rotor arm replacement
Hi All…iv searched but cant find the answer…123 quote…that their rotor is equivelant to bosch rotor arm 1.234.332.024…im after a spare… i can find after market replacements but would like ideally a Bosch or Beru etc…what have you found or used…thanks…Steve …ps its a very frequent question on lotsvof grouos and forums that iv searched…but no answers
Hi Paul…is an 088 an equivelent or replacement for an 024?..cheers…Steve
That’s what came up as a replacement when I put it into the Google box.
Hi Paul…thanks for searching…nothing iv searched has thrown up the 088 as a replacement so you may be on to something there…anyone used an 088 in a 123…or another part number…Steve
I ordered the original from Rockauto but they later reported that they did not have any.
I did find one on-line reference stating the 088 “superceded” the 024 part, but it was in the context of a 123 distributor in a Datsun:
Hi David…yes iv seen that…not sure though that the 088 is a direct replacement…the spec shows it has a 5k resistance…dont know if the 024 has a resistance…will measure the one supplied with the 123…Steve
Ok so a quick update…the original as supplied rotor arm that comes with the 123 has a built in 5kohm resistance…(measured mine)…there are options on the market that are modified and the resistance removed…lots of us useing 123 with presumably the 5kohm standard rotor…and were probably running suppressed leads and resistance spark plug…is there a pro or cons for useing one without the 5k…your thoughts…cheers Steve
