This issue brings back memories from the past…
When I purchased my Sep 1955 OTS back in 1988 car was exceptionally original/low mileage, but aged/tired - chrome was mostly good, but chrome on grille was a little spotted, but not corroded, but eventually need rechroming. The guy I purchased car from - had a spare grille on his garage wall that if not new maybe, was in perfect condition including chrome; so I asked if I could swap grilles over as part of my car purchase deal. Yes, happy to do so, so I immediately removed my original grill and fitted as-new spare grille, but low and behold - same problem as now discussed - the badge extension piece sat proud of the bonnet as per Roger Ks photo. So removed new grille and compared them, and yes, clearly a distinct and measurable difference in two grilles… So I refitted my original grille and left NOS one, back on the garage wall… Twenty years later, I now have had all my chrome redone to ‘as-new’ condition, including my original grille, but then recalled this difference found back in 1988, and never seen anywhere before, any mention of it until now this thread.
I had a close look at mine, and recorded all the casting numbers on the rear, so a record if in case this is an undocumented casting variation with XK140 grilles - several possible explanations, maybe an age related improvement to better fit the bonnet metal shape, maybe a variation to better suit the FHC bonnet which although known to be shorter than the common OTS/DHC bonnet may also have a slightly different profile. Maybe just a quality control batch issue, re molds used for the die casting - who knows, and indeed after 60+ years later of restorations, mix and match grilles/bonnets who really knows…
See attached two photos of back of my original - sits properly on 1955 OTS - grille;
On the left side - cast in 7’ 91984 and a badge - I am guessing the 7’ 91984 may be the significant identifier. The badge includes letters W and B and more, with BIRMINGHAM underneath…
On the right side, just a company badge, which I doubt will be significant unless of course there were two different foundries…, and to date, I have yet/nor tried to identify the badge/foundry with its distinctive W B and S letters and the underneath 1004
So as a starting point - if anyone has an XK140 grille handy/accessible to check the rear side, are numbers/badges the same as mine or different…
And Roger K - given your grille seems to be the different casting (as per the NOS wall hanging in 1988), would be telling what’s on yours…
Solutions…
Bending the grille extension is not an option - die cast aluminium breaks and doesn’t bend…
Sourcing/finding another grille may be an option, if indeed there is something such as these cast in numbers that differentiate…
But I wonder about two different bonnet profiles or not - to suit two different grilles…
