I have purchased an ecu 16 CU Ecu dac4586. Which is the later type for my 1984 my. It has a mini vac resorvoir attached to it. Must this remain or can it be ommited pls
Note this PN is for a non catalytic converter car (IDK it may be that the O2 board is eliminated).
You DO want that vacuum signal damper in place. It helps average out the MAP signal.
~Paul K.
Thank Paul I just fitted the ecu and it works fine, I dislodged the injector resister pack wiring and managed to get the car started without it connected (didn’t know) so it damaged the old pre 16cu saw this on ebay for £50 unknown condition and took a gamble it would be OK and mine was faulty. Am I pleased.
