Greetings:
Just got the S-III back up and running after a 4-year hiatus
Charged the battery (I took it out while sitting) and with nothing else done it started up after 20-30 revs - running poorly as would be expected, gas pouring out of the jet covers on 2 of the 4. Pulled all the carbs and then float bowls to get whatever crud was in there out. I had bought new jet covers from Joe Curto before it went to the dark side of the shop- so the o-rings are new, I applied a liberal bead of vaseline to the o-rings and then inside the plug after installing them. Checked that the floats were all 0.65" from the deck- GTG there.
Also took all the jets out from the jet-carriers to inspect - all B1-BH needles as the service manual calls for. Set them all to 1/2 turn from full rich. Re-installed the carbs, drained the tank of the old gas, added 5gal fresh 91octane. Started car, balanced the airflow, figured some would be running rich due to setting so close to full rich. Could not get the rich indication when slide lifted 1/4". Lifting of each carb seemed to cause a stumble. So added another 1/4 turn towards rich and at this point I only have another 1/4 turn to go. Still no indication by the slide-lift test of rich adjustment. So I took it out for a local drive. I have to say it runs great! In the past, when I would come to a stop the car would try to die, now it doesnāt. Conclusion is that I had the carbs set too lean previously. Also heating has always been a problem if the temp gauge is reading correctly. The car will run at the āNā of the word āNormalā for maybe 2-3 miles but then rises to the ālā. The fan comes on at ālā, and a thermal imager tells me that the temp at the thermostat housing is at about 165 or so when fan comes on. So maybe thereās no problem.
So I drive the car maybe 10 miles (highway) to get gas, and otherwise run the car some to get the juices flowing, running great! Nice to be back in the saddle. Get it home, roll up the drive and into the shop and shut it down overnight. Back out this morning and pull the plugs to inspect. Driverās rear 3 are all bone-white. The rest are pretty well tan, with passenger front 3 having black soot around the inside of the steel jacket but all have tan ceramic and tips.
Last time the car was running - 4 years ago, I couldnāt get the driverās rear carb to richen up enough - and todayās situation is no different assuming the final quarter-turn to full-rich wonāt be enough. What else can I try? If I canāt get it rich enough to tan the plugs from their current white, is it safe to drive the car?
Other issues I have to deal with are a 70# compression on the A4 cylinder, and a faint rattle from the front of the motor at times.
I rebuilt the motor in 1988 and I have 10k miles on the clock from then, 34k total original miles on the car. I did not replace/update the timing chain tensioner at rebuild - dumb me.
Anyone comment on the richening failure, Iād sure appreciate it.
