I discovered my rear exhaust tailpipe hangers, they are on the forward side of the forward fuel tank support cross beam. So yet another difference from later cars. Why should I be surprised?
I finished repairing the rear tank support cross beam.
Bad parts cut away.
The spring saddles were both riveted and welded to the cross beam; I salvaged them. Trial fitting new parts.
Tack welding new parts to old.
Final welding.
The rivets were 11/32" diameter, what a weird size. I made new ones by cutting up a Spax lag bolt.
Locations of spring saddles carefully measured, holes drilled, attached by both riveting and welding. Oxy-Acetylene torch to heat up the rivets bright orange and hammer them against an anvil; I felt like the mighty village smith under the spreading chestnut tree with sinewy hands and brawny arms.
I discovered the DPO had welded on this cross member crooked, the left side ahead of the right side by about 1/2".
I spent four hours calculating the correct position of the spring saddles relative to the nearest reliable reference points I could find, the shock link mounts, which are riveted to the chassis so I figure are pretty accurate.
Measuring, marking, measuring again, fitting and welding the cross beam to the chassis.
Next step, attach the springs.
“Each morning sees some task begun,
Each evening sees it close,
Something attempted, something done,
Has earned a night’s repose.” -
Longfellow
