When attempting to fasten the top to the windshield, each of the 2 side roof rails appear as if they are about 1/4" too short to slide into the accepting slot on the top of ea windshield post. The top does not have any extra play to allow it to come further forward.
Anyone have any experience solving this attachment problem?
Hi Everett,
In my experience all convertibles have a problem that the hood / soft top is folded down for too long and shrinks. I keep the top always up on my E-type except when I am driving.
On my MKV DHC it took me a week of wetting the fabric top and using a lot of force and tools to get the top to meet the wndscreen top rail.
Greetings everyone,
It’s been awhile since I restored my MK IV DHC, however I remember, small adjustments can be accomplished at the turnbuckle behind the inside panels on the left and right side of the back seat. It is forward of the red counter spring tube in the photo.
The first thing is to check how tight the top appears when attempting to attach it to the windshield. Is the top made of vinyl or cloth?
Good luck,
Popop
Hi Pekka,
Thanks for answering. I’m glad you understood my dilemna and that I’m not the only one who encountered this (bad design). For all the mechanical challenges w Jaguars that we encounter, I suppose we could have quite an extensive list of “bad designs” but there’s nothing left to do but find solutions.
I also surmised what you said–that the top may have shrunk a bit because it was indeed down for a long time. I’m surprised the issue still existed all the way up to E-type Jags though !
Thanks again. I will try some wetting and the weather is also warming up now too.
Cheers,
Everett
Thanks for your informative reply, Popop! The picture looks to show an area behind one of the wheel wells and possibly inside the trunk. I’m not sure I can access this easily (har har) but now I have a possible solution. I will check this out !
Thanks again,
Everett
Hi Everett,
The turn buckle is actually forward of the wheel well, right behind the hinge post of the right door, as pointed out in the photo. There is the same turnbuckle adjustment on the left side for left top adjustment.
This issue exist with vinyl tops not only with E-Types but also on other British cars, ie… MGs.
Popop
