This subject has been dealt with before on the Forum and I refer in particular to the excellent video made by Nick Saltarelli. Yet there are many questions left that I would like to have answered before I start lowering the body (and damage the painted body).
I understand the following measures/steps to be taken before the OTS body can be placed:
- There are various ways to lower the body like using 4 big guys (or girls of course), an engine crane or even more sophisticated ways in a professional environment. I will opt for the engine crane.
- It will be impossible to put in the steering column and box afterwards, so these have to be positioned temporarily in the body (to the LH side wall in my case) with lots of protection material.
- In case of the OTS, it seems feasible to leave the radiator (fully connected) on the chassis. The fitting will be tight around the radiator, but it can be done (as Nick S. showed).
- Bumper Support member C.3851 (a.k.a. the cow horns) should be placed first in the body as access later is impossible.
Do others (that have been there…) have additional points/parts that I should put in first?
My specific questions to the collective experience of this forum are the following.
As far as I understand, Bumper Support member C.3851 is (also) connected to the lower part of the Mounting Plate Assembly C.3634 (with the bonnet catch). I cannot find any confirmation other than I see 4 holes in both items. The SPC is not referring to the bolts used for this, nor does Viart provide any information on the subject.
Does someone know whether I can (should) fit these bolts on forehand or is it better to just tie the Cow Horn to the inside of the front of the body?
I also read that someone recommended to fit the Radiator Angle Sealing plates (BD.4630 and 31) at the inside of the wing valences before lowering the body, but I don’t understand that remark, as there seems to be sufficient space to place these plates + felt afterwards. Am I correct?
Thanks,
