Reworking the brake system, new lines etc, found what looks like a fuel filter. Have not found any reference to it.
Is it an Automatic? That looks like an anti creep valve.
Yes it is Automatic. Anti creep heh , learning all sorts of new things. Thanks.
It’s a solenoid valve on the rear brake line. It keeps the brakes pressurized on hills. There is a switch between the carbs. When you blip the throttle the solenoid releases. A lot of owners bypass them
Pst H
Wow! One more exotic technical solution these days.
