1984 XJS Injectors not firing
I believe Clive’s query is “should the Ecu case be earthed”
The case may, or may not be Gnd as a result of internal contacts, but the Ecu doesn’t need the case to be Gnd to function, as there are a number of Gnd pins connected to Gnd point G06.
check each of those pins is providing a good Gnd.
Thank you Clive
Will do that thanks Clive
@ Aristides,
“I think you have to redo the injection harness”
The injection harness is disconnected, I test at the connector .
Disconnecting the harness allows me to free myself from the state of the harness and the injectors.
Stéphane
@ clive_williams
“there is no spark to plugs”
Firts you need to have spark to plugs
You can directly connect a HT cable to the coil output to a spark plug to test without the distributor
Stéphane
