Hello:How do you access the instrument lights,there seems to be little access behind the dash? Thanks in advance,Don
Fairly easy to reach them if you remove the speedometer and/or tachometer.
The speedo and tach are removed by pushing them inward, firmly, and turning. I can never remember which direction to turn them, though. And it’s different depending if you LHD or RHD. Others will remember
DD
Thanks Doug I’ll give that a try tomorrow. Don
On a LHD, it’s counter/anti-clockwise, and it’s < 30 deg turn. You can overshoot the release spot, which I’ve done more than once.
Ron
Thanks:It came out perfectly,I was able to change the bulb.Don
