Ran into two issues today with my XJS. Turn signals and hazards are not working. They came on briefly as I tried over and over again but then turned off.
For the window it would stop just shy of being all the way up. Possible solutions?
I don’t have a wiring diagram in front of me, but are both of those loads connected to the ignition protection relay? If so, that relay might be going bad – relays are often intermittent when they go bad. OTOH, it also could be the ignition switch itself, as it is known for intermittent and corroded contacts inside, one of which operates the ignition protection relay.
I’ve managed to get the turn signals to work by messing with fuses. Still have problem with window. Thinking it is the motor or the rails are gunked
