head light wipers remove and replace 1989
Greetings Dean,
Congratulations, you are happy owner of Jaguar JXS. Please be aware thst Huddersfield slang may be not broadly recognised outside of West Yorkshire.
Not clear from your post, are you looking to remove or replace the arms or just the blades? Or do you want to remove and dispose.
T was able to get replacement wiper blades
Pray tell; where did you find them? I need some replacement fills for mine as well.
Thanks.
SNG Barratt USA division expensive and on back order from UK
e-mail from above co. stated extra 10 to 14 days
Is it just the rubber blades that need replacing? For my old SAAB I would just cut to length the rubber T section from any old blade, and slide it into the old blade holder. Or are they of some non-standard cross section?
Cosmo,
They seem much smaller than typical, but thanks for the suggestion, I will look closer.
Craig
You might look at rear blades used on SUVs; they have a smaller cross section in some applications.
