1991 Jaguar XJ-S V12 convertible with 48k miles, $14,000 OBO. The car is finished in Signal Red (CFC) over Magnolia (AEM). VIN SAJTW4846MC179581
Repaired, replaced all of the difficult, fiddly, tribal knowledge intensive things that can plague a V12 XJ-S. New brake pads & rotors, replaced all suspension bushings, new wheel bearings, drive belts, hoses, and much more.
The paint has held up well and it is still very presentable, but there are paint chips (which were touched up). The body itself is 100% solid and straight. Minor surface rust noted on the undercarriage.
The interior is in nice original shape. Headliner and carpets are good. Dash top is not cracked. Wood trim is complete and not cracked, but has faded to different degrees. The auto climate control system functions correctly… all of the vacuum flaps and the multi speed fans work as they should. However, there is currently no pressure in the A/C system. Rather than saying “It probably just needs some gas”, you should assume this will need some work to bring it back to life.
The car starts easily, hot or cold. Idles and runs smoothly at all speeds. The transmission shifts crisply and the car is responsive.
Opportunities for improvement :
A/C repair as mentioned above
Minor body dings
Hood insulation pad is worn
Grill mounted “V12” emblem is worn.
Tires have plenty of tread and are round with no vibrations, but they are out of date range.
The driver seat is starting to wear in the usual places.
This XJ-S is a very good condition daily driver. You can drive it and enjoy it today and if inclined, spend time to bring it further up to show standard. This is an opportunity to get one that is well sorted and actually works. Offered for sale with a clean Arizona title and repair records.
Contact Richard via PM or at ramiller32@me.com
