beagle47
(David Johnson )
January 23, 2022, 9:42pm
1
Hi all:
Anyone ever try to “recharge” a carbon canister by removing old adding new carbon? Thinking my ‘94 XJS 4.0/6.0 may benefit from one.
Note: just need an opinion or two on “difficulty level” before trying a “do it myself for fun.”
Thanks for any thoughts in advance.
Kirbert
January 24, 2022, 5:51am
2
It’s not hard to do, but why?
beagle47
(David Johnson )
January 24, 2022, 8:55pm
3
Gas odor after driving post hose other updates so narrowed down to a bad connection or canister charge. Note: an amateur here.
Veekay
(Veekay)
January 24, 2022, 10:09pm
4
Is it only occurring after driving, or is it more pungent after you fill up the tank?
I’m going through a problem and it appears that when I fill up the tank, the smell is strongest. As I burn up the fuel in the tank, it gets less pronounced.
beagle47
(David Johnson )
January 25, 2022, 4:18am
5
Only after driving when parked in garage. No discernible smell in cabin or while driving. No leaks. Seems fairly benign.
Kirbert
January 25, 2022, 5:14am
6
Replacing the carbon won’t fix that. You need to correct your vent system.
beagle47
(David Johnson )
January 25, 2022, 5:19am
7
Got it, thank you! Will do some manual review see if I can wrap my skill set around it.
Veekay
(Veekay)
January 25, 2022, 1:34pm
8
Have you replaced that Rochester Valve?
rex647
January 26, 2022, 6:10pm
9
All odours i’v had in the boot was the fuel filter when left pressurised and parked up, I changed it for a barbed fitting one which is also cleanable, and its gone, completely. Not saying its your prob though.
beagle47
(David Johnson )
January 27, 2022, 2:47am
10
Not yet. Found a step by step. Looks fairly easy though.
Grooveman
(Grooveman)
January 27, 2022, 3:07am
11
Here’s what I did back in 2010 …
beagle47
(David Johnson )
January 28, 2022, 9:24am
12
Very cool. Have not started the “adventure” yet but narrowing down the road map. Gas cap whoosh is present so this forum has dropped material clues.
Love this canister hack though. Seriously fun “reverse engineering” by breaking the original down and building your own.
Veekay
(Veekay)
January 28, 2022, 12:58pm
13
Rochester valve replacement should resolve the whoosh.
beagle47
(David Johnson )
January 28, 2022, 4:28pm
14
Not sure if this violates any policy or unwritten rule - if so checking me is welcome - but this link appears to be a good step-by-step:
https://www.jaguarforums.com/forum/xjs-x27-32/guide-replacing-rochester-valve-1992-94-a-200095/
