The car will not start, and the following messages scroll through:; Vehicle too low ; ABS Fault ; Air Suspension Fault. I had switched off the DSC at the consul. So it seems that I have an air suspension fault simultaneously with an ABS malfunction.Since thtis is most unlikely I wonder which one leads to the other. Does this make sense to anyone ??
At the moment I am working on the suggestion that the battery is low ( its 10.1 volts ).Now being trickle charged !
There’s your probable cause.
A new battery has fixed the problem .
