Yes, a bad subject I guess, but it now happened to me!
Just after we did a record run, of 282 miles in one day in Southern Finland, in nice summer weather, the hood down all the way!
But the next day, at first a fuel leak (yes, I had to fill her up with 98E5) and then I ran out of fuel, but in our yard, so no problem. But then I am not sure what were the symptoms and what was the real issue, it ran strangely, like with only a few cylinders…then after it got really hot, I notice the coolant fumes in exhaust! Oh, oh! Shut off, allow to cool, take off the rocker cover, the rocker mechanism, tighten the 14 head nuts, all is well, except that after a test run, even more coolant in the exhaust, I shut off and check the plugs, at first they are fine, except nr. 5 has a huge gap, looks like the center has pulled in, and when I had nr. 6 out, coolant started pouring out!!! :-o
Sooooo, please Ed don’t tell me I need a new cylinder head?!?
Any other way to get coolant into cyl nr. 6?
I was thinking of pulling the carbs and the coolant rail to see what I can find, but I would like to first figure out what the options are.
I do think I may have to pull the head anyways.
The positive think is that it will probably be a lot simpler than pulling the head(s) on a V12 E-type or even the XK engine. The XK could have a simple timing cover problem with similar results, but on the pushrod engine the waterpump can not leak into cyl. nr. 6 or the inlet manifold, as there is none, it’s all inside the cylinder head!
Any good ideas???
Cheers,
Pekka T. - 647194
Fin.
Ps. Like can a head gasket fail so, that coolant will continue to pour into a cylinder, even when the engine is standing still? And shouldn’t an inlet valve also stop the coolant pouring into a cylinder if the engine is turned by hand? (Now it did not. It continued to pour in even if I turned the engine by hand so all valves into cyl. 6 were closed…oh, grief!)
