Evening folks,
I’ve got a query about what should be happening with the fuel pump when I turn the ignition on - hopefully someone can confirm that my car is behaving properly.
My 3.6 manual had been standing for about 3 years without being started - it started fine and I drove it into my garage about 6 months ago and recently tried to get it started again, but although it would turn over, it wouldn’t fire. and no fuel is getting to the engine.
I’m fairly sure that this has been caused by sediment or rust in the fuel tank which has blocked the fuel system and caused the pump to fail. I checked today and found that almost immediately after turning the ignition on, the fuel pump receives 12v and then about 5 seconds later I can hear the relay click and the supply turns off. The pump doesn’t run at all when connected so is in need of replacement but is that electrical behaviour correct?
I’ve ordered a new pump and will fit it in due course - I’ll also empty the fuel tank tank and swirl pot out and clean through the pipework before adding new fuel.
As I’ve discussed elsewhere in another thread, this car is facing an uncertain future and may end up being used for parts, but I’d like to get it moving so that I can move it about the garage and also prove that the engine is healthy.
Many thanks everyone
Simon.
