I know that Paul Cangialosi’s JT-5 is the best option, but he iscurrently not making them, and the assiciated parts which make it a bolt on replacement for the all synchro Jag bix and OD.
So what is the best alternative, incl ease of installation and getting the shifter in the right position?
Peder
I cannot say whether this will fit for sure in a RHD 420G, but I fitted a similar one to a S2 V12 XJ tunnel, replacing a BW12
I fitted a W57, and it was great, need to machine a flywheel centre to attach the ring gear, and I believe the original pedal box can be modified to take the clutch pedal.
I obtained the parts from another person, turned out to be the original prototypes
I fitted a Supra W57, the tunnel is very tight on 420G
- I forgot to mention there is a Jag I6 to Ford T5 bellhousing listed
How far forward is the shifter in the 420? I’m using Paul’s bellhousing to convert my Mk2 but I’m using a full size T5. The shifter might be a few inches farther back but in the sedan there’s more room to move the shifter around.
Some other options:
https://thedrivenman.com/c-968306-shop-by-category-transmission-kits-jaguar-mk1-mkii.html
https://www.terrysjag.com/category/PERFORMANCE-5-SPEED-COVERSION-KITS.html
Gerard
Terry´ s stopped making the bellhousefor the 4,2 block. God knows why, and Paul Cangialosi is currently not making boxes or bell houses…
Paul C is still selling bells I just bought one a few months ago.
