Hi Guy’s… does anyone have an engine wiring schematic…foe 4.2 with points … I am missing the full 12 volt supply to the ign coil ? Art
Don’t have a '68 diagram but an S2 diagram should be of some use as it is most similar to an S2 car rather than S1.
pauls
Thanks to Mike Frank at CoolCat…
One comment on the wiring diagram- my early Series 1.5 does NOT have the starter relay as shown in the schematic. The white/red wire goes from the ignition switch directly to the solenoid. Bad for the ignition switch, I’ll likely figure out a way to wire a relay in anyway…
And my very late (57th from last) Series 1½ doesn’t have it either. I suspect none did.
I must be losin it… I do not see the distributor and the diagram ? or
perhaps the coil ??? Art.
Jagart;
Distributor:
Right upper corner of diagram just under the heated rear window.
Regards, Joel.
Hey Joel thanks for sure… I guess I need a diagram like the xjs…
with # 's …LoL…Art…
No ballast resistor in '68, either.
Hi Michael,
my 68 has a ballast sitting just above the coil area....not
sure who the previous mechanic was…so what do I look at next… hard
starting wnen cold…Art…
