Hi Richard and others,
Let me preface by saying that I really do try and work things out on my own before I bother you guys…
Well, I am still at this main harness layout. I am working with a new harness kit from SNG. The main harness is what I am referring to. The right side of the main harness includes: the very end, which connects the right side harness that feeds the hand brake and right rear side stuff…; the right side door switch; starter motor, starter relay; wiper motor; wiper washer.
All of these wires run off of the main harness and “y” off from the main. So I relocated the wiper motor and washer and starter motor through the right side hole per Richard’s picture. All good!
The problem is that the short amount of cable via another “y” spit off from the main harness is not long enough to reach the starter relay.
I have tried also running the starter relay wires through the firewall hole on the left lower side of the washer res. Still not enough cable to reach!
As I lay the wire harness out, it appears that if I relocate the starter relay inside the firewall, under the dash on the right side, all wire seem to work…
Has anyone else installed a new harness kit from SNG? Any advice is greatly appreciated!
Thanks,
Bob
