Hi I’ve missed you all, I’m sure you probably haven’t missed me
Anyway I’m back on my Series III and it ran great when I put it away for the winter, unfortunately my baby had to sit outside under my $100 garage.
I made it out 1" PCV pipe and a tarp. FAQ "How didn’t you put a curve in PCV pipe? Answer - made a jig, and filled the PVC pipe with hot water. Anchor with 6 concrete (cinder) blocks to keep it from getting air born. I’ve included a picture for anyone that cares. That’s a topic unto itself.
Borrowed my wife’s tool of choice - the hammer. gave the starter a tap tap with a dead blow hammer. she fired right up - not my wife the S-III. Got her up to temp, then turned off, flipped the key to the go position and she started up again. Excellent!
Time for a bath, and go for a spin, Started to took her off the jack stands, turned the key one more time to make sure she was healed. Nope. Turned the key to the go position and nothing. Not a click (like a starter solenoid) absolutely nothing.
Well for F!@k sake. Checked the battery, holding fast at 12.6v (no load). Pulled the battery out and checked starter connection on the poll behind the battery. The connections, looked fine.
When I pulled the battery I evicted the a mouse family who took up residence behind the battery during the winter - blew it all out checked the wires and insulation all looks healthy. I checked the wires to the starter they felt snug. I bit tight for a visual inspection. From what I could see all looked well and connections are snug. There was wire fabric frayed around the main starter to battery and the ignition (white & red striped) to the solenoid wire(s) it looks like either the fabric frayed because of the metal tie down holding it or my recently evicted residences were snacking.
I hooked up my remote starter switch. nothing… No solenoid click - nothing. Crap! well I have a Series II starter kicking around did a bench check with the S-II starter much to my surprise it worked.
Well before I started on the job of pulling the starter, So I decided to turn the ignition key again and zoom! My green kitty fired right up. Ugh; an Intermittent problem. I let her run for a bit, turned her off. let her sit, then fired her back up. let her run a bit longer get up to temp. shut her down, fired her back up.
I did this for an hour or so. and all is well.
I let her sit for several hours while playing taxi to my daughter and came back to fire her up again. and nothing. back under the car, I cleaned the grease and dirt off with CRC electric motor cleaner.
I’m leaning towards the ignition wire to the starter.
Any thoughts.
Thank you in advance.
