“…the AAV which I belief is working correctly”; ‘belief’ is not enough, Adam…
The xk is a strictly ‘feet off’ starter - touching the gas pedal; the engine is prone to baulk. To obtain this, the AAV, throttle gap and idle screw setting is working together. They give the engine just the right amount of air for prompt starting, 2 - 3 sec or less, at any temp…
The only temp variant is the AAV; gradually closing as coolant temp rise - a heating coil makes it close faster. The point being that once starting to warm up the engine needs less idle to run satisfactorily. And while driving, the AAV effect is insignificant compared to the open throttle…
While engine cools down; the AAV gradually opens, and ideally takes the correct position for the necessary amount of air. If incorrect, the engine may baulk when warm/hot - an indication of AAV function is the idle when started…
Depending on ambient air; ‘cold’ idle should be some 200 - 400 rpms higher than hot set idle - caused by the AAV opening. Which, while ‘cold’, slide is about 1/2 open - and fully closed with engine warmed up. You can check slide opening in-car at various temps - like at ‘cold’ start, say 80 - 90F when your engine baulks. It is not conclusive, of course, but may offer clues…
The AAV can be tested out of the engine by heating and cooling - observing slide movement. Due to the build-up of gunk in the slide tracks, the slide may be erratic - ‘massaging’ it with a small screwdriver, the slide is moved by a bimetallic spring, may ease the slide movement…
As a crude test; you may ‘strangle’ the AAV by clamping the air hose to it - engine may get too much air for effective starting…
While engine will start OK at various idle settings; it is important that idle is set with engine fully warmed up. And the AAV slide must be fully closed when hot idle is set - otherwise cold/warm starting may be affected. As a curio, when doing shopping, the short cooling may throw the system off kilter - the AAV and engine doesn’t quite agree. This shows up as delayed starting - and the idle, when started is lower than hot set…
Some components, like ign amp and coil, may become heat sensitive - impairing ignition. Usually this shows up with the engine hot, whether starting or driving. Ignitions should then be tested; connect a spare plug, triple gapped, to any plug lead - and observe spark quality. Which should be strong and blue - but it should be counterchecked with engine cold, to see any noticeable differences. A weak yellow spark may still run the engine effectively - though indicating impeded ignition…
With temp related problems, the resistance/temp gradient of the CTS should routinely be measured - including wire/connector integrity. Just changing the CTS may be insufficient. Indeed, changing components without some verification of their status is not really ‘best practice’ - components working to spec cause no problems…
As for ‘choking’ the engine by blocking the AFM inlet; this effectively stops air flow through the AFM. This means less deflection of the AFM flap - and the flap position tells the ECU how much fuel should be delivered. Ie, ‘choking’ the engine this way prevents both air and fuel to the engine. Which may have some diagnostic value - engine response may tell something. Or the engine may have started anyway - one method if the ECU is confused, is to crank WOT…
Frank
xj6 85 Sov Europe (UK/NZ)
