anyone know the part number or an aftermarket impeller cage/fan blade? I have 20 units lying around plus 2 in car that work fine but broken blades. that plastic does lot last well. easy enough to press on another cage but finding one that fits is almost impossible. The cages are similar for 8 years from 88 to 95
Have you tried an hvac supplier? Or maybe grainger.
Steven …
I’m sure there isn’t a Jaguar part number for just the squirrel cage impeller, or the motor and the impeller either.
The lowest sub assembly is the entire blower unit.
I’m afraid that your best bet is to continue your search for a used jaguar blower unit or an impeller from another car that is compatible in size.
Just out of curiosity how did you end up with 20 Jaguar impellers ?
I likely have some used ones.
One thing I noticed working on these is that the fans are stamped R or L.
I thought this meant the position on the car, but it’s the direction of air flow from the fan.
The RH fan needs to blow left into the matrix for example.
Rob
