So the wife and I were having a lovely end of season run, up one side of the mountain, down the other, lots of fun 15 mph switchbacks, 150 miles or so, and a mile from the house the brake pedal sinks to the floor, and nothing happens but the right rear locks up. By divine intervention, I was travelling slowly, and there was no traffic, and the light turned green just as I arrived at the intersection.
It is, of course, the Teves. Put an accumulator on it a year or two ago, it pumps up in under 45 seconds, (it’s the next size larger than what came originally) and currently takes 4 or 5 squishy pumps for it to turn back on. I bled the system per the book after awakening the car from a 10 year slumber back in 2020.
Symptoms: almost exactly at the halfway point in the trip the right rear brakes squealed coming to a stop. Has never done that before, and didn’t do it at all on the way home.
ABS light is on, has been, don’t know that it has ever worked
Felt something not quite right at the stop light about 2 miles before the one where the pedal went soft.
upon putting it into it’s resting place, the brakes sort of worked, although with a very soft pedal.
now if you press the brake pedal, it sure feels like there is air in the front circuit, with the pedal seemingly finding something solid near the bottom of the travel.
Any other car I would be blaming the master cylinder, because the brakes were working and then the pedal went squishy with no other issues.
But this is the first car I have had with this system, and all I’ve read says the master rarely decides to quit.
So what’s is all yall’s opinions on what could be happening here?
Was the squeal was the pistons in the caliper coming loose, and travelling far enough that it took more than one pedal travel to make up? But that wouldn’t leave me with a squishy pedal now.
The accumulator ruptured? But it’s still pumping up.
Give up on the ABS and put the previous generation master cylinder on it with the booster, and abandon the Teves?
I need something to hang my hat on, my wife already doesn’t trust the car, and frankly, if all I do is bleed it and all is working again, I’m not sure I can either.
I have been running this car all summer with no issues, and the fluid is less than two years old.
My OCD kind of demands I know what went wrong before changing anything.
Thanks
71MKIV AKA Steve
71 Spitfire
91 Jag XJS classic convertible
“reliability is overrated”
