Replaced the pump, but not getting any pumping action, beleive it is vapor locked? How do you prime the pump? Is there a bleeder valve to let air escape? Thanks JC
John:
While I’ve not done a pump on a Jag the one’s that I have done take a few turns, lock to lock to chase out the air. If all is installed correctly and the pump is not defective this should do it.
Good luck,
Ed in Dallas
Thanks for your response found the pump was defective all is good now jc
