Thanks I found it this morning and it is fine. Cleaned the evap, careful with the hosme boy thosel drsims sre slow. Found my drivers side blower won’t run at max it starts to go but then slows to about med, going to pull tomorrow for visul. Any way to hook up 12 volts on the bench to check speed ops?
David …
After you pull the assembly you certainly can apply 12v directly to the fan motor and that will tell you if it’s working. That simulates the top speed.
Success, removed the blower, easier than the passenger side, seperated rhe housing, liberal amount of corrosion block on everything, 12 volts runs full blast now. Reinstalled and now have plenty of air! Whole job took about 2 hours. Thanks everyonel for the help!
David …
That’s very “cool” to hear you fixed it !
With a lot of helpful info!
