WHEN I TOOK THE RADIO out there were 3 vac pipe, blue red and white in sight, the white has a T on it, the T was disconnected on the downward bit but question is, where does the downward bit go,
Rex,
That should connect to the rubber hose which feeds the servo vacuum switches for the hot water valve and center dash vents.
Access thru the right hand vent cheek panel.
Gary
thanks Gary. …
