The cloth surface is coming off the inside of my A pillars. I need to take them out to
get them recovered.
Does anyone know how to do that?
Thanks,
P.
I found instructions in the factory manual, it says to first remove the door weather seal. Has anyone here done that? Is there any trouble replacing it again?
Thanks,
P.
I got my guy to pull back the weather stripping and found a little black plastic clip near the top of the interior panel, which detached without breaking and we pulled the panel loose from there. The weather stripping went back on without any trouble and he is sending off for a matching material.
Thanks,
P.
Thanks for following up your post with the solution. Very helpful for your fellow listers.
Cheers, Alan
Photo showing the cover removed, with the black plastic clip hanging loose. It reinstalled nicely after the cloth was replaced.
The original cloth has some cushion backing that dried and the material was not wrapped around the edges of the cover, so you couldn’t reglue it without having glue marks on the surface when you were done.
P.
