Pulled into the garage with a cloud of smoke today, coming from the hood.
Popping it open revealed smoke coming from the front of the AC compressor.
It looks as if the clutch seized.
Checking on-line reveals clutches are not sold separate, and the whole assemblies are not available.
Are there substitutes (GM, Ford, etc)? And if so, would they be fairly direct swaps or miracles of adaptation?
What kind of car? And/or what kind of compressor?
DD
Same thing happened to my '74 XJ12 years ago, it is a standard GM compressor, I got one from a used parts recycler, came off a Cadillac as I recall.
Woops, sorry 'bout that.
'77 XJ 6 - C
You probably have the Harrison/GM âA6â compressor. Tons of parts are available, including clutch assemblies. Complete rebuilt compressors are readily available as well.
Also, some vendors sell a brand new, updated version of the A6
Google âHarrison A6 Compressorâ and youâll see lots of choices for parts and replacements
DD
I believe that the A6 is identical to the GM A6 so here is the seal rebuild kit I got for mine, I have yet to install it but it looks like it should work. Doesnât hurt to rebuild once its out anyways, its a while youâre in there kinda thing. https://www.shopcenturyautoair.com/store/c29/GM_A6_Compressors.html
Ok, you guys have given me some good info.
Thanks
Mitch, if you put that info into the âMy Carsâ field in your profile then people can see it when they click on your avatar.
Thanks, I gotter done.
Wait, didnât they use a different thread for the mount?
I think mine is metric and not sae. God knows why.
No shortage though, youâll find dozens for cheap.
Did the clutch seize or the compressor?
If you were not operating the A/C, itâs possible (but rare IMO) that the clutch idler bearing itself seized. More common would for it to become noisy, then perhaps become hot enough to smoke.
If the A/C was on, then the compressor itself seized (more common) which would make the clutch smoke if the belt were still turning it, or more common, cause the belt to slip. OR, the clutch simply slipped, generating heat, because it lost adjustment or wore outâjust like the clutch between engine and tranny.
My point is that compressor seizure can result in crud remaining in the system. You can tell if it seized by determining if you can rotate it. Without knowing the condition of the clutch, the simplest way to do this is remove the belt and (first) try rotating the pulley by hand. If it rotates the compressor, the clutch has failed. If it spins freely, try rotating the compressor itself (part at very front of clutch). If that rotates, you are probably OK. If it doesnât, the compressor has seized. IMHO.
t this point (The clutch got hot enough to burn off the paint), Iâm just planning on changing out the compressor.
Obviously at this time I might as well convert to 134a.
Are there any vids of this being don on S II cars?
It all looks straight forward, but this is a Jaguar, so there must be a catch somewhere.
I did this on my 1984 Series 3 last month and I couldnât find any videos on the whole interwebs, at least not for old Jags.
Lots of opinions and approaches to r134 conversion, all in the archives.
As far as the refrigeration side of Jaguar climate control, itâs all plain as mud. Nothing exotic about it at all.
'Tis the control side where things get a little weird
DD
Jaguar (and GM) used both.
Make sure your bolts fit before attempting to mount the compressor. Itâs struggle enough without discovering that you have the wrong bolts
DD
Mitch,
I donât believe that switching over from R12 to R134A is "obvious ". I have recently repaired/restored inoperative R12 A/C systems in three of our Jaguars and had them all seviced professionally with R12 after I made sure that I fixed the leaks (o-rings, hoses, compressor).
The A/C systems in these older cars were designed to work with R12 and from what I have read the R134A conversions donât cool as well. Search for a recent string from Mel Friedman about this.
I have one more inoperative Jaguar A/C system to fix (1990 XJ-S convertible) and will be keeping that an R12 serviced system as well.
There is a lot to read about R134A conversions in the Jag-Lovers archives.
One of my reasons for converting is there is only one shop in town thta
does r-12, and heâs getting old.
It just seems the conversion now is
wiser than a conversion in a few more years.
maybe Iâm wrong -
although that would be my first this century (Not!)
On
Mitch,
have recently
our
sure that I fixed the leaks (o-rings, hoses, compressor).The A/C systems in these older cars were designed to work
with R12 and
this.I have one more inoperative Jaguar A/C system to
fix (1990 XJ-S
serviced system as well.There is a lot to read about
My current compressor is a GM
[quote=âdavidsxj6, post:10, topic:378172, full:trueâ]
Wait,
I think mine
No shortage though,
[/quote]
struggle
DD
[Visit
Topic](Ac compressor kaputt - #15 by Doug_Dwyer)
or
reply to this email to respond.
To
unsubscribe from these emails, [click
here](Jag-lovers Forums).
Mitch,
I just wanted to point out that you had more choices than to automatically do the R134A conversion.
Oh, I understood that. Iâm just looking up the road a few years to
continuing R-12 availability.
Mitch,
do the R134A conversion.Paul
[Visit
Topic](Ac compressor kaputt - #19 by Paul_M_Novak)
or
To
