I will have to do longer trips with our Mk2 and the range gained by the original tank is by far too short. I saw pictures of additional tanks formerly supported by coombs. Does anybody know something about those or similar tanks - where to get, how to install ? Or is this too exotic ?
while I have no practical experience with an aux tank, I often thought that a fuel cell would fit in the back of the boot or trunk under the rear parcel shelf without interfering with the rest of the boot storage. I have an old Deliair Air/Con unit setting back there Add a second fuel pump and a switch - your good for 500 miles!
You could use a tank from a Triumph Spitfire , just a bolt on job , add a filler cap like the Coombs or mount the tank low , so filler is out of sight !
thanks a lot for you quick and very helpful messages.
Having been victim of a screw in one tyre once, I want to keep the spare wheel.
Fuel cell is a good idea, Spitfire tank is the one that I want wo try first. What I don’t quite understand, is how to mount the tank low ?
I would try to get it situated in the region in the boot, where the rear axles lives underneath. The filler would go out either on the top (if there is enough space above) or at the front (unvisible), with a tube connected to be filled at the side of the tank with the boot lid open. That correct ?
I would be extremely cautious about re-engineering the fuel system especially locating a filler in the boot. Where are the fumes from the filling process to go except down in the bottom of the boot thus creating an explosion hazard. With any spilled fuel the situation will be even worse. All the piping and connections will have to have absolutely perfect integrity. Just ask anyone who was with Jaguar Cars in 1988 when the Hess & Eisenhardt convertible conversions were done on the XJS coupes andt the issues that the modified fuel tank system created.
