Old thread, might have connections to my problem?
Hi
I drive an XJS V12 Coupe 5.3 liters 1993 with catalysts and Oxygen sensors
Have spent many hours on trying to find out why the car only spins when flooring it from stop during the first 5 or 10 minutes of driving (when starting from cold engine), and after that period of time it does not spin from stop anymore that day. The loss of power is significant, but only during takeoff and only during the first 1 or 2 seconds, during these seconds the car does not even manage to spin from stop on a gravel road!
This loss of power comes instantly, in the blink of an eye. Suddenly the engine becomes âtiredâ. But â only the first seconds when flooring it from stop.
The rest of that day (as long as the engine is running at working temperature) it will not spin again when flooring from stop. Have to wait many hours until egine is cold again to be able to spin the wheels from stop when flooring the pedal.
The acceleration is always normal/correct from 15 â 20 mph and upwards, the problem with loss of power is only during the first 1 or 2 seconds when flooring after takeoff.
Top speed of the car is correct.
TPS works perfectly fine; 0.32 Volt to 5.0 Volt), so does all other sensors. New sparkplugs, new ignition coils, new cables and new ignition amplifiers. Marelli system. Throttle linkage OK (and correctly adjusted), new air filters. Fuel pressure regulator (only one on my car) working fine. MAP vacuum hose to ECU works correctly.
When standing still at a red light I can hear by the sound of the engine if the car will spin or not, when OK the sound is more vivid, and the idle RPM is about 100 higher compared to when the engine is âtiredâ. I also notice that if I shift the gearbox to P or N and floor the pedal for half a second, the RPM âjumpsâ to 2.000 in the blink of an eye when the engine is OK, but when it is âtiredâ the increase from 750 to 2.000 RPM goes much slower. A huge difference!
Since this big loss in power comes instantly (after 5-10 minutes of driving from cold engine) I do not think the problem has to do with any mechanical issue or with faulty sensors.
Maybe the fuel mixture suddenly (after 5-10 minutes of driving) changes from normal to very enriched at idle, and when flooring from stop it gets even more enriched (open loop) and overwhelmed /âdrownedâ in fuel for the first 1 â 2 seconds from takeoff?
If so, how can that be confirmed? And how to fix that problem?
I have bought a graphical multimeter, so I can measure, and I can also watch the signals from the sensors. Not exactly sure what to look for thoughâŚ
What is the best way to measure the signals from the sensors (air- and water temperature, flywheel, crank, TPS and so on)? Can I take the lid of the ECU and measure each of them on their respective incoming leads/PIN´s into the ECU?
I have measured the signals/readings AT the sensors, (seems OK) but I would prefer to measure at the ECU (to be sure that the wires/leads are OK between each sensor and the ECU)
Which PIN in the ECU connector is connected to which sensor?
My ECU is a 26 CU. DAC 7188.
Would be nice to also measure the output signal/s FROM the ECU to the fuel injectors. How to do that?
Hopefully your experience will help me with this problem. 13 years with a tired XJS is boringâŚ
Kind regards
Henrik
Stockholm
Sweden
also XJR 2000 and Norton Commando 850 Interstate 1974.
