Hi there, just wondering if anyone has experience of new, but after market, SU carbs - I found these offered by Barrett.
Yes I’m switching out the Strombergs and am in the process of deciding between SU and Weber (but not looking to open up that debate). For cost/originality/performance these after market SU seem good value as a complete kit - but only if they work well out the box!
Experience and views of these type of repro SU is welcome.
It would be worth the ask but I suspect these are made by Burlen Fuel Systems in the UK. They own the SU brand now. So it would be as close to OEM as one could get.
That’s what I’d imagine but SNG has two different price levels, one for SU and one for aftermarket. Maybe in both kits the carbs are authentic SU but in the cheaper ones the manifold comes from somewhere else?
I bought these aftermarket triple SUs , they were made by Burlen as suggested above, replaced my US spec set up, these carbs are excellent quality. Lots of linkage changes needed.
Hi, a few years ago I installed new SU carbs from Burlen made in the UK. They made a noticeable difference in the power, and are extremely adjustable. I have since heard from a professional carb rebuilder that the carbs are now made in China…they are not worth the money. I think my carbs were about $1200.00 new.
Allen
Im thinking of going to triple Strombergs - should give 99 % of the power of the Su s .Just need a new manifold and one CD-2 . The only problem I can see is the Stroms seem wider , so not sure how 3 will fit in the space where 2 went .
The engine has already been rebuilt to fast road spec (distributor changed already) so i just need to decide on a decent tuneable carb setup.
My alternative is the Webers from Rob Beere (includes linkage, air cleaner and purpose built manifold, so good value bolt on and go) - i have some other parts from him and they are excellent quality.
Has anyone tried a Jenvey’s EFI system on an E ? From the outside they look like Webers. If I were considering a major $$ swap I think I would look hard at something like this too.
Be aware that the stronbergs are 1.75” on a 2” manifold. The SU’s are 2 inch. I chose to keep the old manifold and use 2 SU carbs. I modified the air cleaner and throttle linkage to work.
