Exactly
Pressure to high…
the SU 1307 is the choice…mechanical…just touch up the points with an emory board…mostly lasts longer then I will live…
Not cheap…and for some reason went up in price a lot
Mitch
On my Mk IX I’m trying out a diaphram pump made in New Zealand, which has a history of being an alternative to the SU pump. All sealed up in plastic there is no playing around with points. It still has a tick so you know it is going but not intrusive. I bought it during covid when there was supply chain issues. Details at fuel flow 15LM12. Matt
I use the same pump as MARIOCART in my 3.8 Mark 2. No problems, easy to fit and low cost. I bought 2 several years ago. One is carried as a spare in my Riley 2.5 in case the old SU gives trouble. They were about NZ$90 when I bought them - about 45 quid then
SAJ in NZ
The SU sounds great. But because this is going into a '37 Packard body, I need the pump to tuck into frame rail near the tank. So in needs to be an inline type.
I may have found a carter pump that should suit the need based on PSI and flow rate.
