Are you familiar with the part interchange document that was put together many years ago. Some of the part numbers may not be coming up anymore.
Air Conditioning Parts
A/C Clutch & Parts A-6 Compressor
AC Delco
Pulley Bearing 15-2802 or 6557684
Clutch coil 15-45
Clutch Assembly (Hub & Coil) 15-41
Clutch Pulley, w/ bearing 15-224
Hub Snap Ring 15-48
Hub Spacer 15-49
Shaft Key 15-46
Shaft Nut 15-2129
BCA/Bower
Clutch Bearing 907257
Everco
Clutch- remanufactured A8414
Clutch coil A8415
Four Seasons (Division of Standard Motor Parts)
Bearing 25203
Harness Connector-Extender 37209
Harness Connector – Repair 37201
Hub Snap Ring 24175
Hub Spacer 24173
Installation Kit 24169
Shaft Key 24176
Shaft Nut 24172
Snap Ring - Pulley Retainer 24184
Remanufactured Clutch 48284
Conduct-tite / Motormite
A/C Clutch Coil connector with diode – GM 85143
A/C Clutch Coil connector without diode Sanden 84709
A/C Relay connector – Bosch style 4 – 5 terminal 85170
A/C Switch connector GM cycle / Chrysler pressure 85141
BOS / L&S / Perfect Circle
Bearing 907257
Murray
Clutch - w/o coil- 4.75" diameter pulley 261250
Clutch - w/o coil- 4.75" diameter pulley 261264
Clutch - w/o coil- 5.625" diameter pulley 261239
Clutch coil for all of above 261260
Coil connector with diode 207496
Coil connector w/out diode 207402
NAPA
Coil 261260
Hub & Shoe 261255
Remanufactured Clutch w/coil 261250
A/C Clutch Parts Sanden / Sankyo Compressor (’92 - ’96 models?)
BCA/Bower
Clutch Bearing 5001KFF
SD-5 Bearing 25267
“Clutch” Bearing – SD510 25207
Coil - New 47800
Installation Kit 24168
Shaft Key – SD510 24193
DS7 Shaft Seal Kit - SD709 24031
DS5 Shaft Seal Kit - SD510 Not Stocked
A/C Clutch Parts York Compressor (I don’t think any XJS used York)
A/C Delco
Clutch – Mini 206 with 6” pulley 15-4252
Clutch – Model 209/210 with 7” pulley 15-4148
Clutch – Model 209/210 with 6” pulley 15-452
Bearing 25204
Brush 35704
Coil - Pitts 47808
Coil - Warner 47794
Shaft Key 24171
Murray
Clutch - w/o coil- 6.0" diameter pulley 274224
Clutch - w/o coil- 7.0" diameter pulley 274223
Clutch coil - 6.0" pulley 274221
Clutch coil - 7.0" pulley 274222
A/C Compressor & Parts - A-6 Compressor
High Pressure Switch replaced Superheat Switch at Chassis # 139052
AC Delco
New Compressor, with superheat switch 15-2227
New Compressor w/out superheat switch 15-2224
Remanufactured compressor w/ superheat switch 15-2143
Remanufactured compressor w/out superheat switch 15-2141
Suction Cross Over Cover - w/A6 Compr. 15-2229
Cylinder & Shaft Assembly- w/A6 Compr.;
Req. Use w/{15-2191};{15-234};{15-237};{15-290} 15-219
Cylinder & Shaft Assembly Kit w/A6 Compr.
Req. Use w/{15-219} 15-2191
Cylinder & Shaft Assembly Kit] w/A6 Compr.
Req. Use w/{15-219} 15-234
Req. Use w/{15-219} 15-237
Req. Use w/{15-219} 15-290
Compressor Head - Rr.; Non Superheat; w/A6 Compr. 15-2182
Compressor Head - Frt.; w/A6 Compr. 15-229
Head Locator Pin Kit - A6 Compr. 15-290
[Nut Kit] Shell & Shaft;- A6 Compr. 15-234
Oil Pump Kit - A6 Compr. 15-236
Retainer Ring Kit - A6 Compr. 15-235
Suction Screen - A6 Compr. 15-231
Oil Drain Screw - A6 Compr. 15-2140
Oil Inlet Tube - A6 Compr 15-230
Reed Suction Valve Frt. & Rr. - A6 Compr. 15-228
Pressure Relief Valve] w/O-Ring; A6 Compr.; 15-5415 or 15-511
Everco
Remanufacturerd compressor w/ clutch A8604
aka Big A, aka Factory Air, aka Parts Master
Compressor Mounting Bolts – Metric (R4) 12696
Compressor Mounting Bolts - American 12697
Manifold Hold Down Bolt Kit - Metric 12694
Manifold Hold Down Bolts - American 12691
Relief Valve 35753
Shaft Seal Kit – Ceramic 24016
Shaft Seal kit - Steel 24015
Snap Ring - Pressure Switch 24185
Snap Ring - Shaft Seal 24183
Remanufactured compressor w/ superheat switch w/ clutch 57098
Remanufactured Compressor w/o superheat switch w/clutch 57096
Murray
Remanufactured compressor w/ clutch 251129
NAPA
Remanufactured compressor w/ superheat switch w/clutch 251101
Remanufactured Compressor w/out superheat switch w/clutch 251123
VACP (Vehicle Air Conditioning Parts) http://www.vacp.com/catpage.html
Remanufactured comp. w/ superheat switch w/ clutch Non metric V3019
Remanufactured comp. w/ superheat switch w/ clutch Metric V3145
Remanufactured comp. w/ hi press switch w/ clutch Metric V3020
A/C Compressor & Parts - Sanden SD709 – 7494
Compressor - 4.0L Six from Chassis # 139052 – 190527 V3043
Four Seasons
Remanufactured compressor w/ clutch 57586
A/C Compressor Cutoff Switch
Everco
A6 Pressure Relief Valve A7247
Truemark
A6 70 - 79 Axial Compressor with Super Heat 35755
A6 81 - 92 Axial Compressor with High Pressure 35756
4.0L Six - Low Pressure Cutout Switch for rear head V6040
A/C Condenser
GDI
5.3L V12 to VIN 148781 634320
5.3L V12 from VIN 148782 – 188104 (Jag#CBC8540) 634360
