Ok. I got the air pump split into 1 large casting and a rear plate. I got some of the springy parts out through the needle bearing hole, but the rest are too big to come out that way. There a four holes in the front of the rotating cylinder. Do you use a spanner type wrench and unscrew that plate? I’m kinda lost at this point. Thanks in advance. Mike
