1992 3.2 automatic.(uk). All the warning lights (see picture) lights up when engine is running, or even when driving on the road. The car performs great, no issues. So why do I have these dash board indications still on?
Have you pressed the VCM button with just the ignition on and looked for a possible fuse code?
Yes, VCM button pressed with ignition key at position II (engine not running). Car drives and performs OK, just need to cancel these dashboard lights. Do I have a VCM problem?
So no codes then? Sounds like something (relay?) is stuck on but WDIK, hasnât happened on my car (yet)
sorry canât help
Thank you Larry for the reply. Once the problem has been found, I will post it here.
Cheers âŚ> Alan
I donât know about the stuck relay theory, because contrary to an earlier statement not ALL of the warning (red) / cautionary (amber/ yellow) lights are illuminated. Hereâs my '94 in âfull bloomâ:
Methinks the warning lights could be legitimate and result from the previous ownerâs failure to keep up the maintenance / repairs on.the car. These cats do like to be - nay, must be - regularly maintained.
All these red warning lights (in a vertical column to the right side of the display) and amber cautionary lights should illuminate when the key is rotated to the run (II) position prior to starting the engine. If they all illuminate, but some extinguish once the car is running, Iâd say you need to troubleshoot each light individually.
Mike he said the car runs fine - if the tranny light was REALLY on instead of just âlitâ heâd be in limp home mode, right?
Possible that all the other lights are WARNINGS but anti-lock on permanently would mean no assist and very hard pedal.
Stopping a car with that failure is a âstand on the anchorsâ exercise so I doubt that one is ârealâ also âŚlow washers, easily checked, bulb out, maybe, fuse issue âŚeasy to check although doesnât the VCM say where when a fuse has gone? and VCM reports no issues âŚLow rad, again, easily checked.
I think maybe the wiring to the binnacle warning lights or the connection/circuit board in the binnacle is shorting to ground or something like that
Problem found.
Went to change out the instrument panel (for a second hand one) and found one of the 2 plugs that plug into the rear of the instrument panel had removed itself! Fitting the plug back in, and hey presto, all is fine. Did a road test, and all is nice and dandy. I have had the car since June 2019, so wonder if the previous owner(s) [2 off] had done some work in that area and did not refit this plug correctly.
Anyway, please to have the dash board looking as it should.
Cheers âŚ> Alan
Alan ⌠(Esq, does that signify that youâre an attorney?)
Excellent news that youâve solved the problem !!! So many posters donât report back their success.
Was this glitch present when you purchased the car? One thing about The XJ40âs electrical connectors is that when they are plugged together no force on earth, be it earth quake or meteorite strike, can separate them other then human intervention ⌠and then often enough that sometimes isnât enough
Hi Grooveman.
Esq is an old English way re âtitle of respect added after a gentlemanâs name when addressing a letterâ Very rarely used (if ever) these days.
Purchased the car in June 2019, with no problems. The problem happened about 3 months ago. I recon that during its previous life, a past owner may have been working in the area behind the instrument cluster and unknowingly partly dislodged this connector.
Agree, those plugs are very difficult to separate from each other. A lot better design than the Lucas rubbish I have on my other classic cars.
Regards âŚ> Alan
