Tony others will doubtless give more specific info but the head almost becomes the secondry issue in so much that whilst the b type head will physically fit it’s the ancillary connections/interfaces that need thinking thru. Eg what inlet manifold and carbs will you use cams and tach drive connection, (I assume you will just swap them over but then you need to swap the studs etc.) and obviously the throttle linkage etc.
If you use a B head you will gain a significant amount of power. HP goes up and torque comes in much lower when it is most useful. Do you need an early “studless” head, w or w/o siamesed plug wells?
I think the B-Type head as fitted to XK150, Mk I, Mk VIII will be a direct swop as regards the camshaft take-off from the exhaust side? you’d need to swop the inlet manifold over. If the tach take-off happens to be on the RH side, then perhaps a 90 deg angle drive could be used? I don’t think it wouldn’t make sense to use the earlier A-Type cams in a B-Type head - you’d lose much of the power advantage, surely? Just throwing these things out there…
Don’t the cams have an oil slinger bolted into the rear? I presume you could remove that and put the tacho drive in there. Agree about about the low lift cams, though, pretty pointless retaining them with a B Type. As with Tucurious, the performance improvement will be significant, you may end up keeping the B Type in there and keep the A for posterity to be sold with the car.
Something to consider, 2.4 Mk 2 s use the B Type head, but have different cams, so if you buy a complete head, check the engine number on head; 2.4 prefix starts at BG. All others should present no issues.
So 2.4 engines use the same head and only the cam is different?
Please excuse simplistic questions but I am on a steep learning curve and new to XK lore!
The cam shaft part numbers are stamped in very tiny numbers on the rough shafts between two lobes.
The 2.4 L Mark 1 saloon used cylinder head C.6733 with C.4488 Inlet and C.2237 Exhaust cams.
2.4 Mk1 used the A type head with smaller valves and different valve seat angle. Camshaft lift was deliberately small initially to prevent valves clash during handling by inexperienced mechanics; later it was determined this was not much of an issue, so later cams increased from 5\16" to 3\8". Mk1 2.4 produced 112bhp, MK2 with B Type, but still Solex carbs 120bhp and 240 with straight port and 1 3\4 SUs 133bhp (claimed)
I put a 3.8 liter “B” type head on my 3.4 liter block bored 20 over without problems. You may have to change the tach drive depending on the cam. Mine came from a MKIX.
The head saga continues, I have obtained, refurbished and installed a Mk2 B type head and 3.8 cams.
Sadly when I came to timing chain tensioning, the eccentric adjuster is stuck solid.
I have to say that the cam chain was slack before I removed the head - but being new to XK engines the alarm bells didn’t ring!
If only the PO who beautifully painted the outside of the engine had bothered to take similar pride on the inside!
I have followed other threads covering this problem and tried most suggestions including application of releasing fluid, removing the locking pin and spring etc.
Rob suggests that it is in the rear support where the seizing problem lies, unfortunately that area is inaccessible with the cylinder head on.
If I once more remove the cylinder head, how likely is it that gentle application of heat to the area concerned will bring release? Anyone done it with success?
Failing the above, my options seem to be to live with a less than taught chain or remove the chain case and ‘go in deep’.
Anyone got any ideas before I order a new head gasket and crack on?
You must persevere in trying to get it to move with the head on. I have had success when using long nose pliers with a screwdriver between the nose as a lever. I say this for the reason that even with the head off you can’t do much more. Yes I accept access is better but if it’s really stuck you need to strip the timing gear which is another story.
You’re saying the eccentric 20 is stuck inside chain sprocket 19? I would say try the propane torch on the chain sprocket 19. Once it moves, even a little bit, stop and try the penetrating oil again.
