Kirbert
24
Why wouldn’t chucking two blocks together work? You’d have to be careful that the joint line between the two blocks was exactly centered in the lathe, but once centered I’d think it’d work great. And a lot less wasted time and aluminum.
I think perhaps the best fix for the tensioner plug is to buy a brand new rubber plug and immediately cut the ears off of it so it slips easily into the hole. Then fab a small tab to install under a nearby bolt head so that it just presses lightly on the center of the plug. Even if I were to go aluminum with an O-ring groove, I’d still prefer that retention scheme.
There are some issues with 2chunk idea…
First problem is that I have 3-jaw chuck on my lathe, so I can’t hold square stock.
Another problem is that chunks from supplier have precision of ±0,3mm, so, in order to reach desired tolerance of 0,05mm, at least 2 flats (or even better all 4) have to be machined before combining 2 chunks together.
Considering the price of 4-jaw chuck and extra time involved in machining and centering aluminum stock, at current production volume, wasting a bit more aluminum is financially more viable solution.
For tensioner plug I’m planing to incorporate retention scheme in the plug itself. I have few design ideas… Maybe I should share few drawings for forum judgement
That’s exactly what I did. I put a washer in the “bottom” of the bung and have a spring put pressure on it. Unfortunately I don’t seem to have more than this one picture of it.
Well the first lot was sold out in 2 weeks! I think that everyone who has their cam covers off for one or another reason should upgrade to aluminium half-moons. This place with rubber seals is just made for leaks! These aluminium plugs should have been there from the factory…
Kirbert
36
As I’ve said before, the OEM rubber half moons will seal just fine – if you leave the cam cover gasket out and simply seal that joint with Loctite 518. It’s the combination of a rubber half moon and a gasket that does not work, as the gasket is not properly compressed between two metal surfaces over the half moon. So, if you wanna use the cam cover gaskets that you $pent entirely too much money on, you’ll need the aluminum half moons.
Kirbert you are absolutely right about the rubber half-moon and gasket… it just can’t work well. But I would still disagree about the rubber half-moon. How long will the rubber last before it shrinks or hardens? And how often do you take your cam covers off?
By the way I don’t know about the gasket prices on your side of the pond, but here I paid 17eur for one gasket and I think it is a reasonable price. And yes it was updated new type 3-layer gasket.
Kirbert
38
The aluminum half-moon with a gortex sandwich gasket will seal until the sun burns out. The aluminum half-moon with a paper gasket will seal until the sun burns out if you retorque the screws every year or two – but they’re not easy to get at. The OEM rubber half-moon with no gasket using Loctite 518 will seal for 10-15 years or until you overheat the engine badly enough to bake the rubber. Aftermarket rubber half-moons with Loctite 518, who knows? I think we’ve heard a few bad reports about non-genuine rubber half moons.
But, how often will you have the cam covers off to check the valve lash? If it’s more than every 10-15 years, you might as well go with the OEM rubber half-moons. It saves the cost of the aluminum half-moons and the cost of the cam cover gaskets. You just need a new pair of rubber half-moons each time you go in there.
The OEM rubber half moon with a gasket won’t seal, period. Mechs have come to just goop the livin’ daylights out of the area with hylomar or whatnot trying to get it to seal long enough to get out the door.
17eur for a cam cover gasket sounds cheaper than last I checked, but it still doesn’t strike me as cheap.
Kirbert
39
As a quick reminder for all: If you still have the OEM screws with the triangulated threads holding that cam cover on, you need to replace them. Jaguar sold replacement screws, but they must have been a gold alloy based on how much they cost. I recommend either of two arrangements:
“Alloy” socket head screws one size longer than the OEM screws with a flat washer and a split ring lock washer under each head. The flat washers need to be carefully chosen to sit flat in the recess on the cam cover.
Hex head screws a full 3/4" or 15mm longer than the OEM screws with a 1/2" or 10mm sleeve and a split ring lock washer under each head. The spacers stand the heads up and out of the recesses, which are too small for a 7/16" or 10mm hex head to sit down into with a socket around it.
Look at these bolts before you start taking the engine apart, and you’ll see just how difficult they are to get at with the intake manifolds in place. The OEM heads are almost impossible to retorque without taking the manifolds off. The socket head screws are much easier to retorque, especially if you’re willing to saw an Allen wrench to exactly the length needed. But those tall bolts with the spacers under the heads make an absolute piece of cake out of the retorquing job, you can do it with an open end spanner.
Remember, up through 1983 or so, those screws were 1/4"-20. From 1984-on, they were 6mm. Plan accordingly.
Well when I had to change the cam cover gaskets on my old W140 Mercedes V12 I payed arond 40eur for one aftermarket gasket. And they were just simple rubber ones. So I concider that 14eur for Jaguar V12 3-layer gasket is still cheap
