I was going to say standard steel tank will probably outlive you, but then I saw the price difference really isn’t very much. I don’t know why the standard steel tank cost $155!
That’s terrible! What are you using for coolant, Coca-Cola? Crazy. I’ve replaced every single one ( I swear they used to be like $85) and never replaced one twice. Maybe I’m overdue.
Remember, those advertised prices include VAT. When buying abroad, I’ve found when they remove VAT (17.5%?), it usually covers for the shipping. Plus the pound is still quite weak.
I replaced mine last year. I bought the aftermarket steel replacement. My rationale was that the orignal lasted 34 years. The replacement oughta last 12-15 years anyway, even if assuming it is lower quality. I think it was $155 or so. And, frankly, the $400 or so that the SS or aluminum ones cost is just too rich for my blood for such a mundane item.
If nothing else, at the rate the car itself is rusting the tank will out survive the car. [sigh]
I use a universal aluminum one on my XJC. It is the correct capacity. Requires a bit of fiddling to fit on the inner fender. I think I paid $40 for it. Beautiful craftsmanship.
Hi Bob,
I have often thought that the tank you need should be called a recirculating tank, nothing to do with expansion.
You need an inlet and an outlet, and provision for a pressure cap The “capacity” isn’t important as long as you have an overflow tank in your system.
Check out Summit Racing and look for “Joes Racing” expansion recirculating tank, P/no 45010. Less than $100.
