My ac is leaking at the back of compressor… Can the bar at back of the pipes be reversed so it fits tighter… how does the bellows get removed to get at the bolt on the bar… I’ll have some ac guy help
You can’t get the bar off to reverse it without all the freon leaking out. Wouldn’t fix the leak anyway; you need to replace the two o-rings in those pipe connections. That’ll require evac and recharge. Might as well replace that bar with thicker/stouter while you’re at it.
Ok … how about the bellows… can it just be unbolted and set aside while doing the 0 rings
Yes, no need to remove the cable.
