But does the suspension move down at all when ‘bouncing’, Mark…?
You should check ride height for sure - the suspension may rest on, or be very close to, the bump stops due to excessive spring sag…
Ride height should indeed be checked with full tanks; ‘roll out’ to settle suspension - depress on bumper, lift, and slowly release…
If you cannot getting any more fuel into the tank - it is physically full. What it is full of is of course another matter - the floats relating to the tank units floats on any liquid, though designed for petrol. Which is lighter than water, so petrol is on top…
Tank units are not completely reliable - and readings over time with various known amounts of fuel is a diagnostic tool. If the gauge constantly reads above ‘full’ there is an electric short - reading constant ‘empty’ means a connection break. Either requires access to the units by removing the tail light clusters for further wire checks…
As water in the tanks will gravitate to the bottom, where the pick-up is; with a lot of water the pump will feed that to the engine. Which is why the drain plugs are where they are, at the lowest part of the tank - and removing the plugs flushes the sludge sump…
However, as David says; attempt of draining a full tank is not recommended - there is 12 US gallons to be collected, and it will gush. Draining the tank with the fuel pump, collected via the fuel rail hose, has the same demands on collection capacity - and the fuel pump delivers 100 psi of pressure…
In any case; before or later you will have to open the drain plugs, in car or out of it. Open the small one first to completely empty the tank, then the larger one. They ‘usually’ give with little protest…
Frank
xj6 85 Sov Europe (UK/NZ)
