Thanks Frank. Here are the supplied wiring schematic and image of what I assume is the relay mounted on DAC 4090 motor. Therefore I don’t think wiring can be made through original relay and I’m left needing some advice sorting this all out.
I should have included this…
I think you said earlier that BROWN is 12 V constant but I don’t remember which is switched. I need to incorporate all this info into a plan. Can you all help me out?
Alan,
I sent a text to your phone. Here’s my email:
I’m not sure why my messages are not reaching your email!
Richard Greene
[quote=“Alan_Munson, post:81, topic:398466, full:true”]
So would I, Alan…
If the stipled lines indicates a relay it makes no sense it may just be an ‘interconnection’ box - the antenna coax has no relation to the motor - nor has the ‘ant cable’ any relation to it…
If te top picture shows the motor it has a heap of unexplained wires - with no diagramatic relation to colours. So…?
You need to contact the vendor for explanations…? I have seen nothing like it
Frank
xj6 85 Sov Europe (UK/NZ)
Hello again, Frank…
Eureka! Problem solved. Turns out the black “box” with all the wires is indeed the new relay. I simply removed old relay along with blue/white and blue/red wires. That left antenna bundle (brown, white/pink, and black). Temporarily wired brown (12+V) to red, white/pink (switched) to green, and black to ground. Extends and retracts appropriately. There is no 10 second delay with new relay. I re-read your earlier explanations and that’s what lead to resolution. Permanent wiring will come later.
Mounting the antenna with a good seal is presenting a bit of a challenge and the motor does not fit perfectly into the mounting bracket, but I’m hopeful those issues will also be resolved. Thanks for all the help…I’m sure I’ll be back…Alan
A sunshine story, Alan - well solved so far!
Frank
Motor, antenna mounted. I temporarily connected wiring and antenna extends/retracts properly. I’ll make permanent connections, manage wires, and I think I’m done…whew!
yeah, another use for one of my new toyw. I got a Jump box via amazon. slick. Can be used to recharge my cell phones!!!
CHJ
Alan,
Congratulations for getting this sorted out and done.
