I picked up a lot of parts and have some that for sure are not Mk2 or E-type. Are these XK 120 or ?
I’ll post in trader when I can confirm fitment.
Quite a few for an XK120 I believe.
Pic 1
line 1 position 4 headlight ring
line 3 position 1 maybe headlight fitting rings
line 3 position 2 headlight fitting ring
line 3 position 3 alloy car headlight bucket
line 3 position 4 headlight ring
maybe others for spotlights
Pic 3
line 1 position 2 gearstick lever for car with radio fitted
line 1 position 7 maybe bodywork filler panel for in front of fuel tank EDIT got this one wrong, looked flat to me … time for new glasses
centre number plate light housing
bottom left side curtain knobs and escutcheons
red lens maybe taillight
above left of taillight maybe dynamo bracket EDIT actually, no
bottom second from right timing chain tensioner
In addition:
The triangular item with the rubber pads is a broken mount for the wiper motor.
The brake fluid reservoir is from an XK140
The flat aluminum rectangle with the cutout goes in front of the radiator, XK120
The 3-dimensional curved aluminum shroud goes around the fuel filler hose in the boot.
The little chrome rhombus’ attach to the bottoms of the headlamp rims .
The spears next to them are trim for the tops of the headlight rims.
XK headlight rims will have holes to attach the above items. MK2 rims will have a single hole at the bottom.
The boot lid handle is for an XK120
The bracket with the two big holes attaches the wooden fascia panels on a MK2.
The big aluminum stepped angular washer in the bag with the red lens is a front bumper mount for an XK120.
Relay cover is probably for a MKII. I don’t know about 120 or 140, but the 150 only has a single mounting hole on the forward edge, and went to single relay in the later cars.
