Going through my collection of Cheney and Tex hose clamps, it appears there are some anomolies in the Cheney range ?
Although I know most are from '51 MK7s, I have a sneaking suspicion some XJ6 items may have infiltrated, as they seem to have slightly differences, despite being marked the same size
Is there any ways to tell an XK-MKVII Cheney from the later ones such as E-type and XJ?
Not entirely relevant to the specific subject at hand, but not having all the original Cheney clamps from my 120 available in good nick for replating I purchased a set from one of the more well known usuals that (I thought, perhaps erroneously) were represented as faithful reproductions and installed them. When I fired up the engine there were several leaks, including from the hoses entering the heater box, leaving antifreeze sitting atop the carpetting, and leaks upstream and downstream from same leaving green puddles on the floor. Tightening the clamps did nothing. A couple of them popped, making matters worse. Five bad clamps in all, all of them the smaller size. The larger clamps seem to be holding so far. I substituted Jubilee and ratty original Cheneys, all of which did the job. FWIW.
@Nickolas - I just opened up my packet of new Cheney clamps from Moss. There was an instruction sheet included, which gave some specific guides and cautions on the use of the clamps, basically to caution and help avoid exactly what you described. I’ve never seen hose clamps with instructions before! I followed their instructions, and although so far I only replaced the top hose and bypass hose clamps, they are holding up OK (I still have a leak but that is elsewhere).
I followed the instructions too. Again, only the smallest clamps are problematic. The issue seems to be the inside radius directly under the screw - that is, the clamps are not perfectly circular when fully tightened and therefor don’t conform to the hose.
