Hello Bob,
I’m taking a stab in the dark here, but I wouldn’t be surprised if the seal Les has for his B pillar is the exact same profile as the seal with part number BD20500, which is the seal for the Rear Quarter Glass. It seem that this seal is being supplied for the B Pillar with the correct B Pillar Part number (BD28434) applied.
The problem with some of this type of seal being supplied by some suppliers, is that the seal is being molded from two distinct consistencies of rubber; a very dense, quite hard rubber for the T section that locates in the Seal Retaining Channel, and quite soft, spongy rubber for the remainder of the profile. See following picture:
The issue with this construction of seal, is that it resists the closure of the door with a vengeance. So much so, that it makes a good fitting, easy closing door into a rubbish fit and a real door slammer. I experienced this scenario recently with a car in work approaching completion of full restoration, where the doors were a perfect fit and closed well on the old seals. When the new seals were fitted, you would have to take a run up to be able to slam the door hard enough to have them close fully on the locks, (we resisted doing so, of course).
It happened that I had another car in work that had new rubbers fitted from another supplier and the BD20500 seals used on the B Pillar were made from the same soft consistency rubber throughout. As a test, we fitted the softer rubbers to the car we were doing the final fit up before paint preparation, and low and behold, the problem was solved.
On examination of other cars in work for minor repairs, I found that some had the two consistency molded material with the seal cut for its full length, close to the T section on the side with the long flap and a section of the hard material, as close to the Seal Retaining Channel as possible, cut out (see the following picture).
Somewhat like owning a dog and having to bark for it, when you have to mutilate a pristine seal to get the door, or closing feature to close properly.
It comes back to that old acorn, why don’t the after market parts makers stay in their comfort zone by simply copying the original and not get out of their depth by trying to reinvent the wheel.
Bill .
