Hi everybody, last time i got a no start condition no matter what i did, it will no start.
After some suggestions here in the forum, i got a new fuel pump, and that symptom has gone away. i can crank the car, it will take 5/7 seconds, and a little help of the gas and she will start, still idle a little low (had to adjust idle) but start is a giant step from earlier stage.
Now, i have found another problem, that almost left me again in the middle of the avenue when i took the car for a carwash.
After some minutes driving, very gentle with the gas pedal (like 10%) and let the car gain some speed, it will start to bounce the RPM like a hesitation problem. At this stage the complete FUEL supply is out of the equation because it’s working like it’s supoused to.
Here is a video of the problem:
my feet is still at 10%/20% of gas pressed.
Then i opened the hood to see if something has disconnected, and found some oil leak (no problem right now), but nothing else.
So, i decided to try again, and guess what, after some minutes of the car being of, it started without problem, and the hesitation has gone. I suspect that if i had went for a test ride, same symptom would happen.
I am discarding the EFI and the injectors because when the car is cold, and also when i restarted it, it will climb RPM without a problem.
My guess, maybe there are some electric wirings harness worn-out and thus provoking resistance when the engine get hot. Or maybe one sensor at the water rail, or somewhere else?
What do you think??
Where should i start checking?
Thanks a lot!!
Ariel
