BrendanM
(BrendanM)
February 5, 2018, 6:56pm
1
One of these
caused one of those
which via some of this
became one of these on Saturday - some 9 months after the original opportunity
Learnt a lot about XK engines and cylinder heads. Remembered how much I dislike fitting the bottom hose on the radiator. And did some research into engine bay colours too.
Hopefully just a bit of tinkering left before weather warms up and I can add a few more miles.
Nice one, well done, what pistons are they?
Fantastic! was that a dropped Valve?
Phil looks like it you can just see the remains of the stem at about 2 o’clock
BrendanM
(BrendanM)
February 7, 2018, 6:59pm
5
Yes - looked as if it failed at the point of the weld. Then even managed to punch a little hole in the top of the piston. How I laughed…
BrendanM
(BrendanM)
6
Ill check the specs when I get home and look at the invoices - was a few weeks ago I got them now
Tucurious
(Art Ford)
February 8, 2018, 5:50pm
8
Looks like std 9:1 pistons before they had the domes.
BrendanM
(BrendanM)
February 10, 2018, 5:55pm
9
That is correct right - replaced with what has in when took it apart
