I often get a Brake Light Fail message when I put the brakes on. I have tracked the fault to the plug and socket of the left rear light cluster.
In chronological order I have done this:
The resistance of the left cluster to earth was 6.5 ohms. The right cluster was 0.0 ohms as it should be.
I sanded the contacts with 2000 grit emery and sprayed it with circuit board cleaner. Result was 0.0 ohms and no messages
Next day the messages appeared again. Sprayed with CRC. Resistance now 8.4 ohms.
Cleaned it all again with circuit board cleaner. Resistance now 6.5 ohms.
5.Do I give up and run my own wire from the cluster earth to somewhere on the body? The problem is definitely that plug and socket.
It would seem that you have. Rather, it appears that the forum has stopped automatically including that information in our signatures. All this time and I hadn’t noticed even my own not appearing!
