I’ve been having a nasty problem with my ABS. It kept telling me something was seriously wrong with my front passenger wheel. I had the following codes:C1145 -
C1148 - front right wheel speed sensor
Sensor air gap
Wheel bearing free play
Sensor wheel geometry
C1259 - front right wheel speed sensor
Check sensor ring fitment
Sensor air gap
C1234 - front right wheel speed sensor
Sensor air gap
So I took the wheel off to see if something was visibly wrong. I had previously cleaned the sensor, and cleared the codes, but eventually everything came back.
I popped the wheel off, then the caliper, then lastly, the rotor with the hub still attached to it. Even though I was excited to check the condition of the sensor rotor, I actually immediately noticed that the rear hub oil seal had failed. (CBC2858). I didn’t have that part on me, so I reassembled everything, but ju-u-u-ust before I did that, I ran my finger across the stub axle shaft, wiping away the grease, and I saw this:
That ring by the larger bearing…that’s bad news, right?
